electric fan
Old Jun 24, 2013 | 07:05 AM
hawthor's Avatar
Car: 90 RS
Engine: 305 for now
Axle/Gears: stock 2:73
electric fan
i swaped from 305 tbi to 350 carb now the electric fan does not run looking for a little help if some one could tell me were the fan relay is located that would be a big help thanks
Old Jun 24, 2013 | 07:08 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: electric fan
The relay is next to your master cylinder, right next to the fuel pump relay on the bulk head.
Old Jun 24, 2013 | 07:09 AM
hawthor's Avatar
Car: 90 RS
Engine: 305 for now
Re: electric fan
thanks is it the right side one or left what would make it not run any ideas
Old Jun 24, 2013 | 07:11 AM
Engine: Lb9
Transmission: M20
Re: electric fan
Parts on a car are referred to right or left as you are sitting in the car. The relay is on your left side.
Old Jun 24, 2013 | 07:13 AM
Engine: Lb9
Transmission: M20
Re: electric fan
Did you reinstall the single wire coolant temperature sensor back in the rh cylinder head after the swap ?
Old Jun 24, 2013 | 07:17 AM
Engine: Lb9
Transmission: M20
Re: electric fan
Old Jun 24, 2013 | 07:22 AM
Engine: Lb9
Transmission: M20
Re: electric fan
As you can see in the schematic pretty simple. When the green/wht wire is grounded via the cylinder head temp sensor power from the starter junction goes through the relay to the fan. The Splice shown on the brown wire goes to the alternator. Turn the key to run and check to see if you have power on the brown wire. Ground the green and white wire see if the fan goes on. if not move on to see if you have power at the relay on the red wire. Followed bye grounding the green/white wire to see if power comes out the red/blk wire of the relay.
Old Jun 24, 2013 | 07:25 AM
hawthor's Avatar
Car: 90 RS
Engine: 305 for now
Re: electric fan
yes i put the sensor in i put a brand new one in and i also put the one back in on the intake manifold
Old Jun 24, 2013 | 07:48 AM
hawthor's Avatar
Car: 90 RS
Engine: 305 for now
Re: electric fan
what controls the gauge i thought the one in the head was for the gauge
Old Jun 24, 2013 | 08:58 AM
Engine: Lb9
Transmission: M20
Re: electric fan
The left head between cyl 1,3 is for the gauge. The cts for the ecm is in the intake and the fan switch is in the rh head between cyl 6,8.
Old Jun 24, 2013 | 09:02 AM
hawthor's Avatar
Car: 90 RS
Engine: 305 for now
Re: electric fan
The left head between cyl 1,3 iso for the gauge. The cts for the ecm is in the intake and the fan switch is in the rh head between cyl 6,8.
o ok i got ya so i didnt put the sensor back in i have older heads off a 72 350 so ill have to find the wire its a single gr/wht wire i had a sensor right in the water jacket on the block drian on that side would that be the sensor for the fan ill check the old head though might have over looked it thanks alot
Old Jun 24, 2013 | 09:30 AM
Engine: Lb9
Transmission: M20
Re: electric fan
The block drain is 1/4 npt the coolant switch will not thread in without a adapter I believe it is 3/8 npt. It could even be 1/2 npt I cant recall.
3/8" NPT Female to 1/4" NPT Male Brass Pipe Adaptor/Adapter Straight Reducer/Reducing Coupling Male to Female: Amazon.com: Industrial & Scientific 3/8" NPT Female to 1/4" NPT Male Brass Pipe Adaptor/Adapter Straight Reducer/Reducing Coupling Male to Female: Amazon.com: Industrial & Scientific
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
