bench testing wiper multifunction switch
Old Jun 27, 2013 | 11:53 AM
slowboy's Avatar
Car: 1990 CAMARO RS
Engine: 350 - replaced 305 with 350
Transmission: 5 SPEED
Axle/Gears: STOCK [?]
is there a way to bench test a wiper multifunction switch to be sure it is ok before installing it...one on '90 Camaro is apparently bad and I have one in tool box that I'll use if I can be sure it is ok...thanks
Old Jul 1, 2013 | 05:45 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Which Switch Is Witch
Connect one lead of an ohmmeter to the White wire of the switch and keep it there for the entire test.
Connect the other
(which I will call it the moveable lead) lead of the ohmmeter to the pink wire.
When you press the washer lever you should see 0.
Turn the switch to the HI position.
The ohmmeter should indicate between 20 and 30 K.
Now connect the moveable lead of the ohmmeter to the
gray wire.
The ohmmeter should indicate 0.
Ditto for the
purple wire.
Now turn the switch to the OFF position.
green wire.
Now turn the switch to the PULSE position.
pink wire.
Ditto for the
gray wire.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is Sliding On It’s Roof
Old Jul 2, 2013 | 05:55 AM
slowboy's Avatar
Car: 1990 CAMARO RS
Re: Which Switch Is Witch
Thanks for your time, response and the great information NINA
BRoss99
Aug 10, 2025 05:08 PM
mddaniel
Sep 8, 2015 05:16 PM
siberian3rdgen
Interior Parts Wanted
Aug 31, 2015 09:37 PM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
