Electrical issue?
Old Jul 13, 2013 | 06:01 PM
Aluseu's Avatar
Electrical issue?
So I still cant get my car running, starter was just replaced, spark plugs, plug wires, and a new fuel pump and it still wont run, I figured that the fuel pump isnt engaging so Im left to think its an electrical issue, I looked at the fuses under the dash and they all look fine except theres a spot where it says ign (ignition?) and ther isnt a fuse there? am I stupid or am I missing something? I also was told it could be the ignition control module whatever that is.
Old Jul 13, 2013 | 06:54 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Electrical issue?
Does the car crank when you try to start it?
I'm assuming you have a FI pump. Does it do the 2 second prime when you turn the key on?
Have you checked the fuel pump relay?
Old Jul 14, 2013 | 08:37 AM
Aluseu's Avatar
Checked the relay and switched them all around and tried, nothing happened, tun the key and I do not hear the pump prime at all, even before i switched it out, the car cranks but does not fire, I have been having this issue since day 2 of having the car -.-
Old Jul 15, 2013 | 05:10 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Need Fuel 2 Rule
That has nothing to do with the problem.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) see if you have power on pin A of the pump relay orange wire.
(It doesn’t matter what position the key is in.)
If you don’t have power there check the inline fuse located NEAR THE BATTERY.
If there is power there, jump pin A to pin E
gray wire. for a second or two with a piece of wire.
Does the pump run when you do that?
Happy Racing!
I Never Fight In The Pits . . . . . . . . . My Pit Crew Does That For Me
Cornholio7979
Sep 20, 2018 02:31 AM
Gambit TA
Sep 1, 2015 07:27 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
