oil pressure gauge acting up
Old Jul 23, 2013 | 11:45 PM
Crusherfied's Avatar
Axle/Gears: 9 bolt disc 3.27
Suddenly the other day the oil pressure gauge goes weird. As soon as you turn the key on, the gauge reads at max and stays there. A few days later I had the cluster plates off and physically moved the needle to zero, then turned the key on and it kicks right over to max again! What's up???
The only thing I was doing with the car at the time I noticed this was running a jumper wire from the auto shifter switch to the ECM (the idle control wire). I was doing this because the car used to be a 5 speed, but I bought it without an engine and tranny and then swapped in an 5.7TPI and 700R4 that I had as well as the main engine harness and ECM. I wonder if there is a link here?
Old Jul 24, 2013 | 01:20 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: oil pressure gauge acting up
personally I dont trust the stock gauges and would look at getting a autometer one as its more reliable. Its just an opinion tho but if you wanna fix the stock one try a different gauge or cluster if you have access to one. That way you can eliminate the cluste its self
Old Aug 30, 2013 | 11:51 PM
Weird, the gauge just started working again all by itself.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
