Aus tranny
Old Jul 30, 2013 | 04:19 AM
dietmarbrunow's Avatar
Aus tranny
How do i turn off the engine needs service notification on the dash of a 1988 formula firebird?
Old Jul 30, 2013 | 12:22 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Aus tranny
You've got 2 options.....
Fix/repair what-ever failed and is cuasing the 'Check Engine" light to activate.
OR
Remove the bulb from the cluster.
Old Jul 30, 2013 | 05:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Aus tranny
Originally Posted by dietmarbrunow
How do i turn off the engine needs service notification ?
The light is on to indicate you have a problem with the engine.
The correct thing to do is to "pull the codes" to see where the problem is
Read
https://www.thirdgen.org/forums/tech...s-dumbies.html
then disconnect the battery for 30 sec for it to go away.
However if you don't fix the problem that caused the SES light ,then the light will come back on
So if you are not interested in fixing anything ,may as well just put a piece of tape over the light so you can't see it,
until your engine dies or won't start one day.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
