91 Z28 VAT's bypass?
Old Aug 3, 2013 | 02:11 PM
orangek's Avatar
I've been dealing with the VAT's not letting my car start for almost 2 months now, and I've finally decided to learn how to fix it. I read that if you bypass the VATs you also have to bypass something with the ECM for it to start, is that true? And if anyone could link me, or give me instructions on how to bypass the VAT's I'd appreciate it, thanks
Old Aug 4, 2013 | 02:09 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 91 Z28 VAT's bypass?
Have you done anything to identify exactly what part of the VATS system is the problem? Key , relay , module .........?
What do you want to do ?
Bypass the key ( most common cause of starting problems ) cheapest / easiest
or delete VATS completely ; more expensive and time consuming
Two completely different setups ; also related to WHAT is your actual problem ,the popular bypassing of the key with resistors will do little if your problem is with another part of VATS
Do a search , plenty of VATS how to articles on here
https://www.thirdgen.org/vats
https://www.thirdgen.org/forums/elec...ing-v-t-s.html
VATS has 2 parts
read
https://www.thirdgen.org/vats_passkey_system
so you understand what you are dealing with
Old Aug 4, 2013 | 02:00 PM
orangek's Avatar
VATS has 2 parts
read
Well it's not the key I tested that before and it's giving the right resistance, so I'll check those articles out and see what I can find. Thanks
Old Aug 4, 2013 | 02:10 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you want the vats permanently deleted I offer reprograming send me a pm if interested.
Old Aug 4, 2013 | 03:07 PM
Engine: Lb9
Transmission: M20
Pm replied, You will need to remove the starter enable relay and jumper the green and yellow wires if you have your memcal reprogramed. Im not sure what member solicited you but as per thirdgen site rules this is not allowed.
Old Aug 5, 2013 | 03:49 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
SO ?
Just because you can read the resistance of the key doesn't mean the system can
If the VATS module is not reading the key because of a broken wire or dirty /worn contacts in the Ign barrel you see the resistance means little
junior419
Apr 7, 2025 11:35 AM
bbsr72
Sep 27, 2015 05:55 AM
Formula8r89
Sep 22, 2015 04:24 PM
sahlomonic
Sep 20, 2015 07:15 PM
Winchester1094
Sep 15, 2015 09:48 AM
