Alternator Wiring
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
Alternator Wiring
Please help, have a 1992 Camaro RS, my car is equipped with a 2 wire style alternator, I know where the RED wire goes, but where does this BROWN wire connect to, can't find a matching brown wire, so I'll have to extend it and connect it to its correct source, can you guys tell me where that is????
Thanks in Advance....
Re: Alternator Wiring
On my Z28 the brown wire is supplied from a splice in the harness that is fed off the 20A "FAN" fuse that is hot with the key in RUN and goes to the F (or I, different name on some) terminal on the alternator/generator.
If it's the original stuff where did the brown wire in the engine compartment harness go?
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
eightsixseven
Dec 16, 2024 01:50 PM
Dialed_In
Aug 20, 2015 01:45 PM
db057
Aug 11, 2015 10:11 PM
