6 cyl tach to 8 cyl tach
Old Aug 6, 2013 | 09:14 PM
Gus68's Avatar
OK, first let me apologize if this has been covered. I have searched and searched and keep finding things for the 90-92, but I have an 87 firebird. Anyway..... My 87 firebird originally came with a 2.8 v-6, now it has a 350. The factory tach does work, just reads higher than it should, which I assume is because of the extra 2 cyl. Now I am sure this can be corrected with the right amount of resistors, and I do have the tach apart right now. I just don't know which resistor you need to change and by how much. Thanks for any advice!!!!
Old Aug 6, 2013 | 09:43 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: 6 cyl tach to 8 cyl tach
Oddly enough I just covered this : https://www.thirdgen.org/forums/elec...-89-tachs.html
The first one was a V6 tach that I converted over for a V8, but the second repair method in post #17 of replacing the feedback resistor (using 192 kOhms instead of the 256 kOhms for the V6) will also work.
Old Aug 6, 2013 | 10:32 PM
Gus68's Avatar
Hey thanks for the response demented. But I think the circuit board in my 87 firebird's tach is a little different. yours looks like it is about the sise of the tack face. Mine is just a little guy about 2 1/2 inches long by about 1 inch wide with 3 metal tabs with screw holes to help hold it to the instrument cluster.
Old Aug 7, 2013 | 07:11 PM
Gus68's Avatar
Anyone???
Old Aug 11, 2013 | 01:06 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Theyre all the same circuit, but with different PCBs. If you post a pic, I can point out what needs to change.
$750 L98
Feb 1, 2025 02:25 PM
bjpotter
Oct 4, 2015 07:48 PM
Eric-86sc
Sep 28, 2015 11:37 AM
armybyrd
Sep 15, 2015 06:06 PM
TrevinE
Sep 14, 2015 03:20 PM
