What does this warning light mean
Old Aug 13, 2013 | 01:39 PM
casson4's Avatar
Car: 1985 camaro berlinetta
Engine: carb'd lg4 305
Axle/Gears: 3.08's sonn to be 3.73's
I have an 85 berlinetta with the digital dash and when i was driving home and an annoying buzzing sound started so i pooked at the dash and there was a N. whats that mean ill post a picture
Old Aug 13, 2013 | 01:46 PM
casson4's Avatar
Re: What does this warning light mean
I posted a photo in my phoo album
Old Aug 13, 2013 | 02:03 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
That's not an "N". It's supposed to depict the choke blade in the carb.
The light means there's an issue with the choke.
Old Aug 13, 2013 | 02:37 PM
casson4's Avatar
thanks for reply but the
p.o. switched the stock carb to a edelbrock manual coke so what should i do
Old Aug 13, 2013 | 03:01 PM
casson4's Avatar
could it be the choke heater fuse
Old Aug 13, 2013 | 06:09 PM
That light says "choke" but it's REALLY the alternator light.
Happens all the time.
Odds are, you need an alt.
https://www.thirdgen.org/forums/carb...oke-light.html
Here's a similar thread from just the last couple of days.
Old Aug 13, 2013 | 11:50 PM
casson4's Avatar
Thanks for reply im gonna test the alternator tommorrow
Old Aug 16, 2013 | 12:42 PM
casson4's Avatar
i went to autozone and its not the alternator.... what else could it be
Old Aug 16, 2013 | 02:06 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Since you no longer have it hooked up, the choke wire could have shorted out on something and blown the fuse.
Old Aug 16, 2013 | 11:28 PM
casson4's Avatar
what wires are for the choke
Old Aug 17, 2013 | 02:22 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Your alternator is probably fine and will test fine, but the plug &/or the wires could be probably the problem. The Choke relay is also suspect,... I'm guessing that you already checked the fuses !?!
Carefully inspect 2 terminals inside the prong alternator connector,... They are notorious for getting covered in crud and even becoming weak & breaking off. Also caefully check the BROWN wire as far as you can because that's the one that controls your warning light.
These should allow you to figure it out.
Old Aug 18, 2013 | 02:44 PM
casson4's Avatar
ok so today i got another 20 amp fuse an put it in as soon as i turned the key it blew so i knew there was a short somewhere then i looked in the engine bay and found a wire that must have been cut from when the P.O. was installing the eldebrock carb. this wire was being grounded by the valve covers. thanks for all your answers
Old Aug 19, 2013 | 11:20 AM
naf's Avatar
naf
Remember where that wire is when you later add an electric choke.
383cam
Sep 9, 2015 06:01 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
