Choke Light
Car: 1982 Camaro Pace Car
Engine: 305 4bbl
Transmission: 4 spd
Choke Light
I have an 82 Camaro Pace Car, 305 LG 4. It's the factory carb. The choke light comes on and stays on. I checked and the choke is open and car seems to run ok, but is a bit hard starting when it's warmed up. All the linkage seems to be working free.
Any ideas??
Any ideas??
Re: Choke Light
Needs an alternator.
That light is REALLY the "alternator" light. It was mis-labelled that way because in the factory's (or more likely the EPA's) infinite wisdom, it was evidently deemed that warning of this emissions-related consequence (the choke doesn't open properly if the alt isn't working) was more important than telling the driver what's actually broken.
Engine: 305 4bbl
Transmission: 4 spd
Re: Choke Light
Thank You. I changed the alternator and the light went out.
Car: 1985 camaro berlinetta
Engine: carb'd lg4 305
Axle/Gears: 3.08's sonn to be 3.73's
Re: Choke Light
i have the same problem but i went to autozone and they tested my alt. and its fine .... what else could it be
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
