Electric Hatch release upgrade
Old Aug 23, 2013 | 10:23 PM
SuperHawk996xx's Avatar
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
ok, I do not have the push button hatch release on my 86' T/A. I had it on my previous firebird and loved it. I just bought the solenoid off Ebay. Can I just install the solenoid on my existing hatch setup and run wires for power and illuminating the switch? or is there more to this?
Old Aug 23, 2013 | 11:34 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Electric Hatch release upgrade
i think GM also put a relay in the system, too.. at least i think that's what that relay under my center console was for..
Old Aug 24, 2013 | 11:45 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
There is less to it. The connector for the switch is already tucked behind the center switch console. You just need to cut a hole or get a piece with the correct number of holes. The wiring in the trunk is all there. Just plug in the solenoid lead. The hardest part is finding the connector under the passenger side dash and plugging in the relay. All plug and play.
Old Aug 26, 2013 | 10:09 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Be sure that you've got the correct soleniod before geting to involved in the upgrade.
The 82-85 Hatch release soleniod is NOT the same as the 86-91 hatch release soleniod. The soleniod used on the 86+ PPD hatch motors will not work on a 82-85 body.
Old Aug 26, 2013 | 07:23 PM
I had no idea there was a difference. My car is an 86' model. The description on Ebay said 82-92. I know some of the componants to the 91 and 92 hatch pull down motor was different but thought the solenoid was the same.
Old Aug 26, 2013 | 10:39 PM
John in RI's Avatar
I found a pic:
This one will work on 86-91 hatch motors...... The manually operated cable gets removed and this soleniod operated cable gets screwed to the PPD unit.
82-85 soleniods will not fit a PPD motor & the 92 hatch release is a completely different unit so stay away from that one too !
Old Aug 30, 2013 | 10:36 PM
Ok, I the one I bought looks to be like the one in the picture. My car is an 86' model. Whats the different between the one for the earlier car and the 87-90' solenoid?
Old Aug 31, 2013 | 11:01 AM
John in RI's Avatar
This is a picture of the 82-85 Soleniod..... Obviously not compatable with PPD cars.
punkmaster98
Sep 30, 2015 11:01 AM
amcnellis
Sep 16, 2015 04:16 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
Randomtask2
Sep 10, 2015 08:37 AM
scottmoyer
Sep 7, 2015 07:06 PM
