VATS Bypass
Old Sep 1, 2013 | 03:18 PM
Napaman08's Avatar
VATS Bypass
What is the proper resistance for an 89 Camara 305 TBI A/T? I have it to where it will crank just not turning the injectors on. I was told you can put and inline resistor to bypass it. The resistance on the key read 4.67 ohms. But I need the proper resistance as from stock.
Unless there is a better way.
Old Sep 1, 2013 | 06:20 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: VATS Bypass
VATS takes out both starter and injectors , if it cranks unlikely to be VATS unless someone has already bypassed the starter relay
If the ICM in the dist is faulty it will not signal the computer to fire the injectors
What is the proper resistance for an 89 Camara 305 TBI A/T? The resistance on the key read 4.67 ohms.
https://www.thirdgen.org/vats_passkey_system
Old Sep 1, 2013 | 06:23 PM
Napaman08's Avatar
Re: VATS Bypass
yes the starter has been bypassed.
Old Sep 1, 2013 | 06:41 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: VATS Bypass
Old Sep 1, 2013 | 08:47 PM
Napaman08's Avatar
Re: VATS Bypass
I measured the key pellet and it measured at 4.67.
Does this mean that I would use key code 11?
Old Sep 1, 2013 | 11:24 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: VATS Bypass
key pellet measured at 4.67.
That what it said here
Is nice to mention important little details like that when seeking help for a problem.It may have a bearing on the solution
junior419
Apr 7, 2025 11:35 AM
$750 L98
Feb 1, 2025 02:25 PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
Racerx974
Sep 19, 2015 10:16 AM
