berlinetta headlight upgrade?
Old Sep 14, 2013 | 08:42 AM
nater's Avatar
Car: 1984 camaro berlinetta
Engine: v8
I was reading the tech article on upgrading headlights. from my understanding all that you are doing is adding relays and larger guage wire to a car w/o relays.
My high beams keep tripping the circuit breaker and I know some of the lights have been replaced before (I wouldn't say upgraded though).
The berlinetta already has a relay system for the head lights so to "upgrade" it would I just run larger wires from relay box to headlights? or am I misinterpreting this.
Also I'm pretty sure its tripping the circuit breaker, but could something else cause my lights to go out after running my brights for a few minutes?
Old Sep 14, 2013 | 03:49 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: berlinetta headlight upgrade?
unless someone put put high wattage high beam bulbs in your car the likely reason the crcuit breaker keeps tripping is a skinned wire thats touching metal somewhere.or maybe your light switch is worn out.
Old Sep 14, 2013 | 05:55 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Or a bad ground on the core support.
Veaceonee
Sep 29, 2016 08:15 PM
manifoldsrme
Sep 17, 2015 11:40 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
