dash lights dont come on
Old Sep 16, 2013 | 07:27 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
hello all i have a 1992 firebird im restoring.and ive come to this problem the last owner put a aftermarket radio in and then when he sold it to me he took it out and gave me the stock radio. now heres the thing i have gotten it wired back in but now when i turn the lights on the radio light turns off and the dash lights dont come on. what could it be thank you.
Old Sep 23, 2013 | 05:20 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash 4 cash
Make sure the dash dimmer control is set at the bright position, then using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe BOTH sides of the INST LPS fuse.
If there is no power both sides check for power on the
orange wire at the headlight switch.
Then check for power on the
dark green wire at the headlight switch.
Is there power on both wires?
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Old Sep 23, 2013 | 09:52 PM
mikey8494's Avatar
Axle/Gears: stock
Re: dash lights dont come on
it works found out that you cant seeit come on except in the darkso used to bright new dashes of my 2000 neon
Old Sep 26, 2013 | 10:35 AM
gman41's Avatar
I agree, when I fired up my old 1987 I was unnerved at how dim the interior was at night.
Pilotrick50
Sep 2, 2015 12:48 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
