Mini starter & DVM question
Old Sep 16, 2013 | 09:00 PM
bourneash's Avatar
Car: 1988 Iroc
Engine: 383
Transmission: TH400
I am redoing most of the wiring in my vehicle and have starter specific question. I have a mini starter and am using a digital volt meter for testing
One wire going to the starter is hooked up to the battery and supply's a constant +12v... The other wire when connected to a +12v source causes the started to engage and spin (starting the engine). If I have my digital volt meter with one lead grounded and the other lead connected to the +12 that causes the starter to engage AND have the digital volt meter set shows at trace signal I am seeing a connection to ground on this lead (with the vehicles ignition disconnected).
Is this normal?
The starter operates fine when I have the ignition key hooked up and when I have the ignition hooked up I am also seeing the ground trace signal at the crank fuse when the ignition is off.... When I turn the key to the start position he ground trace signal goes away.
Old Sep 17, 2013 | 06:38 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: Mini starter & DVM question
What kind of DVM do you have. It sounds like your DVM is completed the circuit and may be bad.
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Wesly_66
Aug 26, 2015 09:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
milk
Aug 10, 2015 06:26 PM
