Gas gauge drops quickly!
Old Sep 18, 2013 | 10:51 PM
Ratchet23's Avatar
Car: 1991 firebird
Engine: 5.7 v8
Transmission: manual
Ok so I did my v8 5 speed swap and ever since then my gas gauge hasn't been working I fill it often so I know it has plenty of gas but I fill it and it is pegged, and the. Al of a sudden it will go down a little bit then just drop fast like 4 minutes or so and it is empty I check the wire and the ground strap for the sender but nothing has changed. What could It be and how should I go about fixing it? P
Thanks in advance
Chris
Old Sep 23, 2013 | 05:23 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Big Hole In Fuel Tank !
Here’s how to test the fuel gage.
Remove the sender wire going to the gage.
Tape the bare end of the sender wire and put it aside.
Use a potentiometer with a value of 100Ω or the closest you can find.
Connect one end the potentiometer to the gage from the location you removed the sender.
Connect the wiper of the potentiometer to ground.
Turn the key to RUN.
Slowly adjust the potentiometer from 0Ω to 90Ω.
If the gage is bad it will exhibit the problem you have.
If the gage is good it will display a smooth transition from one end of it’s range to the other.
Therefore the problem is with the sender or wiring going to it.
You can use a loose potentiometer, or you can throw together a quick little panel like this one.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
crazynights
Aug 21, 2015 06:53 AM
