Gauge's Out
Gauge's Out
I have a 1987 Camaro V8. The gauges are out along with the Tach being pinned straight up. The Tach will move with the rev of the engine but then go back to straight up. Speedometer works fine.
Dash lights are partialy out
The trunk motor does not work as well. It previously had.
I bought the car new in 1987, it was my first new car. I had it parked for the last five years and had a shop get it up and running again last week.
My only conclusion is there is a circuit or fuse that is bad. Am I right or going in the wrong direction.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Gauge's Out
Car: 86 IROC
Engine: 5.0 TPI
Re: Gauge's Out
itll be a black wire with a round eyelet.normally it is on the steering column brace.remove the column trim for access
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Junk In The Trunk
You will have to describe the problem.
Too slow?
Won’t always open? Close?
Happy Racing!
If My Engine Has An Illegal Part, And The Inspector Doesn’t Hear It, Does It Make A Sound?
