battery drain over nite, this relay??
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ive searched the threads about draining batterys, mine drains over nite after charging... is this the starter relay up front near battery connected by a tab??? I heard if its defective it will stay on and drain battery??? anyone have the part number or a way of testing it?? im gonna check all my grounds, fuses etc and do a parasitic test later.... hope I spelled that right ;-)
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: battery drain over nite, this relay??
I thought the starter relay it was inside the car ?
https://www.thirdgen.org/forums/post...447-post5.html
If the starter relay was faulty and locked in the closed position your starter would be running
If there was a fault in the control side of the relay it would do nothing as that only has power going to it when the Ign switch is in the START position
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, what is that relay up front by battery? p/n??
Fan relay
raymondandretti
Sep 27, 2015 06:43 PM
