Turn Signals
Car: 1984 Trans Am Recaro
Engine: 5.0L V8
Turn Signals
when i turn the blinkers on both sides for the tail light stay solid instead of bliking and for the front only the left side marker flashes the 2 main ones near the headlights do nothing same as the right side marker when i use the emergency flashers the tail lights flash and so does the left marker what should i do to get everything working right
Car: 1985 Camaro Sport Coupe
Engine: Chevy 3.1
Re: Turn Signals
Did you put in a new socket for the front turn signals? I wired the socket wrong and that same thing happened to me and I wired the socket wrong. Should check that.
Car: 90 Iroc Vert
Engine: 5.0L
Re: Turn Signals
Is the blink a fast blink ? Flasher gone bad ?
Not even sure if these car have flashers modules> but I remember the old cars I used to have had them.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Flash Dance
First check the bulbs to make sure they are the correct type, and installed correctly.
A common mistake is people installing 2 filament bulbs 180° rotated.
Some crazy symptoms have been reported doing that.
However the likely cause is a partially disconnected or faulty Hazard / Turn Signal Switch.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is Sliding On It’s Roof
Happy Racing!
MikkoV
Sep 9, 2015 04:25 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
