Computer removed, won't turn over?
Old Oct 9, 2013 | 04:22 PM
N.J.-SLICK-1's Avatar
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
Need help Guys, I have a carbed 406, figured I'd clean up the wiring, remove the computer and tidy up under the hood, but now motor won't turn over by ignition switch, I have a remote starter solenoid with mini starter, and when I use a screw driver on the S side of solenoid to Batt side it will spin the motor, but utilizing the key gets nothing, what did I overlook or miss?
Old Oct 9, 2013 | 07:16 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Computer removed, won't turn over?
Originally Posted by N.J.-SLICK-1
now motor won't turn over by ignition switch, what did I overlook or miss?
If you are using the stock starter wiring to power up the remote solenoid then the starter enable relay ( previously operated by VATS )
needs to be bypassed
Old Oct 10, 2013 | 07:41 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
from the diagram it looks like if you connect the yellow and drk green together that will bypass that relay
Old Oct 10, 2013 | 02:21 PM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Thanks guys, I appreciate this info, and I've even done a search to help me better understand what was being explained, I have work to do this weekend!
Old Oct 12, 2013 | 07:28 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Old Oct 12, 2013 | 08:36 AM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Originally Posted by vetteoz
Thank you so much for the illustration, this makes this far more simple for someone like myself!
Old Oct 12, 2013 | 09:51 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
the diagram i was looking at was on austinthirgen,
Old Oct 14, 2013 | 05:09 PM
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Worked like a charm guys thanks once again! (More questions to follow!lol.)
Derick15
Sep 17, 2016 05:28 PM
E Rod
Aug 28, 2015 05:17 AM
ZsTransAm
Aug 11, 2015 07:30 PM
BrianI
Aug 9, 2015 11:52 AM
3rdgenparts
Aug 8, 2015 07:09 PM
