1985 firebird v6 5 speed manual IGNITION PROBLEMS!!!
Old Oct 15, 2013 | 03:03 PM
jrmints1415's Avatar
Car: 1985 Firebird
Engine: 2.8l V6
Transmission: 5 speed manual
So here's the deal, I bought this car off Craig's list last month and got all the mechanical components and what I assume I did the wiring too. The issue I am having is I can't get the engine to crank over. I got a new battery and a multimeter from napa. I tested the voltage to the soleinoid when in stop and start and I didn't get any. All my accessories work such as lights and wipers but the starter won't turn. It is a brand new starter and I even removed it and tested it with a wire shorting it with a battery and it works perfect so I know it isn't the starter. Upon further investigating I found a pretty thick purple and yellow wire going go what looks like the clutch safety so I shorted it with a paperclip but still nothing. Then I found the same purple and yellow wires going to the trans but not plugged in (person I bought it from replaced trans and never plugged it in I guess) so shorted that with a paperclip too. Still nothing. Please help I'm very frustrated!!!!!
P.s. sorry fir such a long post
Old Oct 15, 2013 | 03:04 PM
Car: 1985 Firebird
Engine: 2.8l V6
Re: 1985 firebird v6 5 speed manual IGNITION PROBLEMS!!!
I will post pictures later tonight
Could it be fuses, bad ignition switch, some safety feauture I didn't over ride??
Old Oct 16, 2013 | 06:45 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Starter wires don't run to trans , if you have those colors there then they should be for a speedo sensor (VSS )
Upon further investigating I found a pretty thick purple and yellow wire going to the clutch safety so I shorted it with a paperclip but still nothing.
What you need to do is with key in START position check the yellow wire at the clutch switch .
Do you have 12V there?
If no power there you need to check for power on the yellow at the Ign switch in start
Maybe a faulty or out of adjustment switch
If you have power at those places need to use the DVM to check for a broken wire somewhere along the circuit between the Ign switch and the solenoid
Old Oct 23, 2013 | 07:52 PM
Car: 1985 Firebird
Engine: 2.8l V6
I have a few updates about my electrical mess. There are a few things I forgot to mension before so here we go.
1. When I first found the clutch safety I shorted together and when I turned the key it cranked over very slowly.
2. My battery is in perfect working order and even tested on another car
3. My engine is not seized as I can crank over with a ratchet and is the same tension as my other car.
4. When I was cranking engine over slowly some smoke came out from the vent on the passenger side dash top.
5. In the pictures you can see behind the clutch pedal there is a little metal "lever" switch (originally mistaken for the css) so maybe the previous owner did some sketchy wiring of a new switch.
6. There are lots of unconnected wires under dash
7. I tested exactly what you told me to do and I got 12v from the yellow wire to css and just for fun tested the wires I was talking about by trans and also got 12v from the yellow when key is in start.
8. When I put the key in I get a coolant light, and a continous buzzing sound until I jiggle the key a little.
Here are some pics any help is GREATLY appreciated!!!!
Attached Thumbnails 1985 firebird v6 5 speed manual IGNITION PROBLEMS!!!-imag0015.jpg   1985 firebird v6 5 speed manual IGNITION PROBLEMS!!!-imag0007.jpg   1985 firebird v6 5 speed manual IGNITION PROBLEMS!!!-imag0012.jpg
Old Oct 24, 2013 | 08:36 AM
N.J.-SLICK-1's Avatar
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
start checking for body, chassis, and engine grounds, then make sure all wiring that are possibly hot are taped until you find their location.
Old Oct 24, 2013 | 10:28 AM
Car: 1985 Firebird
Engine: 2.8l V6
So I followed the ground and noticed that the big gauge wire is attached to the frame but over top of paint (not sure if it matters) and the other little ground looks like it is burnt off so I'm wondering if the circuit is properly grounded. I'll post some pics of it when I get home. Thanks for all your help!!!
Old Oct 24, 2013 | 08:02 PM
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
the large guage "ground wire should go to the engine then the little one 10 guage prefered to the body, and a second to the frame. the smoking you saw was a wire somewhere burning up because the power found a parth back to ground that it wasnt supposed to take. this is proly why the motor turns over slow, improper ground
Old Oct 25, 2013 | 05:06 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I feel for you after seeing those pictures. Some people should not be allowed to work on any part of any car.
Old Oct 25, 2013 | 07:37 AM
Car: 1985 Firebird
Engine: 2.8l V6
haha I know but thanks I got the motor to turn over. It was a ground problem! Now to get it started...
Hotrodboba400
Dec 10, 2019 07:07 PM
Lbibb
May 5, 2016 12:00 AM
bjpotter
Oct 4, 2015 07:48 PM
tattmann
Sep 27, 2015 05:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
