Adding Accesories
Old Oct 21, 2013 | 01:37 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
Adding Accesories
I want to add some additional electronics to my car. I would like to add additional circuits which will be 12 v Keyed. I was wondering if it would be safe to run a wire with a male spade to an aux fuse box from the factory box under the dash. (Attached what I have in mind below.) I then would run the additional electronics off the Aux fuse box.
I wanted to run 2 -3 Autometer Gauges, and 1 or 2 12 volt Aux Fans in the interior ( no longer have AC in the car.). The draw of all of the above items should be less than 20 amps.
If this isn't a good idea can you suggest something else?
Old Oct 21, 2013 | 02:28 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: Adding Accesories
i would take the brown wire that fed the a/c blower and use it, should come from 25A htr-a/c fuse
http://austinthirdgen.org/mkportal/m..._continued.gif
Old Oct 22, 2013 | 04:53 PM
THETANK's Avatar
Car: 91 rs
Ok thanks, i'll give it a shot.
Ed1LE
Sep 30, 2018 09:14 AM
86IROC112
Nov 7, 2015 06:50 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
