hid
Old Oct 28, 2013 | 05:27 PM
Psudokiller's Avatar
Car: 1992 camaro rs
Engine: 3.1l v6
Transmission: t5 5speed
Axle/Gears: 7.75" 9 bolt, 4.11posi, disc brakes
hid
just bought a true hid projector kit, two actually cause i have dual headlights, both headlights are dual beam projectors with true hids, 8000k 35w, they are housings that mount in the factory location with factory hardware so that is not an issue, now to the question.
each headlight has a ballast resistor and each pair has its own controller, as i have limited room i am wondering if anyone has ideas on where to mount the resistors (two per side), my only idea is to make a plate that mounts them next to the battery and charcoal cannister on either side right behind the headlights on the inner fender portion of the front sub frame, here is a picture of my kit,
Old Oct 30, 2013 | 07:51 PM
Car: 1992 camaro rs
Engine: 3.1l v6
Re: hid
installed and hooked up, they work great, the ballast resistors are just sitting there for now but ill figure that out later
Old Oct 31, 2013 | 12:29 AM
Car: 1992 camaro rs
Engine: 3.1l v6
Re: hid
still need to be aimed properly
Old Oct 31, 2013 | 06:15 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: hid
Very nice, where did you get them and how much were they? Getting a lot darker outside should help your night vision a lot.
Old Oct 31, 2013 | 06:56 PM
Car: 1992 camaro rs
Engine: 3.1l v6
Re: hid
a place called modify street, $192 for both kits so half for one
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Fronzizzle
Aug 19, 2015 01:36 PM
F-Body Tim
Aug 20, 2004 09:40 PM
CrazyHawaiian
Oct 1, 2003 09:41 PM
MrDude_1
Jul 12, 2003 06:04 PM
