inaccurate temp gauge fix
Old Oct 31, 2013 | 12:41 PM
xx138xx's Avatar
Car: 94 camaro
Engine: 5.7 KT1
Transmission: 4L60
Axle/Gears: 10 bolt with 3.73
So I Have been battling a inaccurate temp gauge. I have finally have found a good fix. After buying several aftermarket temp sensors from autozone and oreillys. Some one suggested to buy the the correct AC Delco temp sensor part number # d1885 . My gauge is spot on now. I have verified with my laser temp gun. Alot of people trash the gauge itself for being inaccurate but its most likely the sensor. Also a great tip I read from a member NINA. He said to use a 2k potentiometer to sent the correct ohms to your temp gauge and see where it reads. Its a great way to tell if your temp gauge is accurate or not. I figured I would share this info. It help me a lot so I hope it helps someone else.
Old Oct 31, 2013 | 04:15 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: inaccurate temp gauge fix
excellent .thanks for the post,as many if not all of us have this issue.good work
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jk_Under
Sep 8, 2015 08:13 AM
85Special
Sep 3, 2015 04:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
