TRC?
Old Oct 31, 2013 | 04:36 PM
Cale Sahl's Avatar
Car: 1992 Z28 Z03
Engine: LB9
TRC?
Can somebody help identify what this part is please? It says TRC, then below it 016C. Found it connected to the bundle of wires that hooks up to the positive lead of the battery. Is this something that needs to be hooked up to something? And what does it do?
Old Oct 31, 2013 | 05:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TRC?
https://www.thirdgen.org/forums/tech...formation.html
Old Oct 31, 2013 | 05:37 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cruisin’ 4 A Fusin’
That’s a fuse holder.
Disconnect it and you will find out if it’s hooked up to something.
Happy Racing!
Spin Me This Week . . . I’ll Spin You Next Week
Old Oct 31, 2013 | 06:35 PM
Cale Sahl's Avatar
Car: 1992 Z28 Z03
Engine: LB9
Re: TRC?
Thanks both for your replies. I assumed my signature (which had my car info) would show up, but I didn't look that far into it.
So the TRC box is just a fuse holder? So I can just attach to a bolt or chassis ground and it'll be alright?
Old Oct 31, 2013 | 07:59 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: TRC?
A fuse is installed on a supply wire to protect a circuit.
Batt Pos terminal - fuse - item being protected - ground.
The fuse doesn't go on the ground side of the item as you suggest.
It would do nothing.
As suggested you need to find out what circuit / item it is or was protecting
Old Oct 31, 2013 | 09:51 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: TRC?
This is not totally correct, a fuse could be installed on a ground lead of a device. There is equal current flowing in the ground wire as there is in the positive wire of a device.
Generally though on negative ground vehicles the fuse is installed in the positive side to blow in the case of short circuit of the supply wire.
FreeSpirit
Jun 5, 2013 04:07 AM
sparks454
Nov 26, 2012 12:14 AM
dan0617
Mar 10, 2012 08:45 AM
GofasterFirebird
Jun 17, 2008 09:48 PM
