Is this the starter relay bypass?
Car: 1989 Camaro
Engine: 305 Tbi
Still trying to figure out the wiring mess from the previous owner. Im pretty sure i have a vats issue because the starter won't engage. I tried putting the resistor in but it didn't do anything. I've read about bypassing the starter relay is that what this is?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Is this the starter relay bypass?
https://www.thirdgen.org/forums/tech...formation.html
Would appear your starter relay is gone
not with the relay bypassed
Need to go through the whole starter circuit from Ign switch to starter and see if you have power all the way through.
Your Ign switch may be faulty or out of adjustment .Your NSS or clutch switch may be faulty ( have no profile up so we don't know what we are dealing with ! )
Have you hotwired the starter to confirm it actually works?
Car: 1989 Camaro
Engine: 305 Tbi
Car: 82 Z28
Transmission: T400
Installing it may add to your current problems
Just leave the 2 wires joined as they were
Car: 1989 Camaro
Engine: 305 Tbi
Was messing with it today and figured id check the N.S.S. because it was the only thing i hadn't checked and it was unplugged the key is working fine now. I just need to get my new fuel pump in to see if my injectors work and it should be running.
Car: 82 Z28
Transmission: T400
Gunner242
Dec 25, 2015 04:49 PM
