Headlight Question 1989 RS
Old Nov 12, 2013 | 09:31 AM
topn01's Avatar
Car: 1989 RS
Engine: 305 TBI
I just had my 89 RS re-painted and I have a headlight question. I am almost certain that before, all four headlights were on when switched to high beam. Since I got it back from the shop, only the inside headlights come on in high beam and the outside headlights go off. Vice-versa in low beam. Which is correct? Thanks in advance.
Old Nov 12, 2013 | 12:05 PM
ajStyles2015's Avatar
Car: 1989 & 1990 RS V8 TBI
Engine: 305 5.0 L
Re: Headlight Question 1989 RS
is it possable that all four of the headlights are hi beam? the way it should be is the two outer lights should be hi beam/low beam and then when you turn on the high beams all four lights in the front should come on...
Old Nov 12, 2013 | 01:14 PM
topn01's Avatar
Car: 1989 RS
Engine: 305 TBI
That's what I remember. In looking at some other posts here, that is what should happen. I'm thinking that either the high beam filaments in both outer lights went bad, they got the headlights swapped outer to inner, or the wires were swapped when they put it back together. I was just trying to be sure that all four should be on in high beam before I took it back to them. Thanks.
Old Nov 12, 2013 | 03:58 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
the outer lamps should have a three wire connector while the inner lamps only have a two wire connector. it's possible that the wrong lamps were re-installed as the two wire (high beam) lamp 'could' have been installed in the outer positions.
test the three wire connector for power to two leads with high beams 'on'. clean the contacts, reinstall the connector and check your lamps. clean your ground leads and ensure good continuity to chassis ground. there should be a ground lead at each set of lamps.
Derick15
Sep 17, 2016 05:28 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
