Testing a instrument cluster out of the car...
Old Nov 17, 2013 | 05:37 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Hi everyone, I have a quick question. I removed the 145 MPH speedometer from my 87 IROC and I plan on selling it, however, it is pending on whether or not the thing actually works. There is no engine/trans/interior in the car and I don't have another fully wired up camaro to plug and play to test it. Is there any way that I can test this thing? I know the speedometer works as does the odometer, but the trip odometer does not work (it stays at 0 miles). I would like to test the voltage, fuel level, coolant temp and tachometer functionality, but don't know any of the electrical diagrams on the printed circuit at the back of the cluster. Can anyone provide any insight?? Thanks a bunch! Paul M
Old Nov 18, 2013 | 02:49 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Testing a instrument cluster out of the car...
Austinthirdgen.org will have the wiring diagrams, then its a matter of feeding it what it wants, the voltmeter will obviously want voltage. The other gauges I believe all work off of resistance, so just tie a wide range variable resistor in with the cluster main power feed on (and grounded properly) then pipe in the signals and go through the full spec range
Old Nov 18, 2013 | 06:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Trip odometer fix below:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Nov 27, 2013 | 04:50 PM
paulmoore's Avatar
Originally Posted by JamesC
Thanks for that! I will have to try this (very carefully) and see if it solves the issue. I work for a dealership and my parts manager knows a guy who specializes in instrument cluster rebuilds. He confirmed that everything works (minus the trip) but that the speedo is noisy and groans during operation. Quick question for you...how would I go about lubricating the speedo to quiet it down? Is it even possible? If so, what would be the best lubricant to use? White lithium? Molybdenum? Thanks!
Old Nov 27, 2013 | 06:26 PM
JamesC's Avatar
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Elephantismo
Feb 13, 2019 12:51 AM
James Sutton
Sep 23, 2015 02:18 PM
James Sutton
Sep 23, 2015 01:56 PM
CatmanFS
Sep 19, 2015 09:00 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
