parasitic draw
Old Nov 21, 2013 | 03:55 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
parasitic draw
How many mili amps sould be ok for are cars when its off. If I dont drive it for 2 or more days its dead
Old Nov 21, 2013 | 04:44 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: parasitic draw
I would say 50-100 but im not a good source of info.
Old Nov 21, 2013 | 07:30 PM
Sojer's Avatar
Re: parasitic draw
50 Ma
Old Nov 22, 2013 | 10:29 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: parasitic draw
where did you get that, that seems like too much, i would think like 10-20ma would be normal
Old Nov 23, 2013 | 05:39 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: parasitic draw
If your battery is dead in two days don't concern yourself with an exact number. Have the battery and alternator tested for free at any auto parts store. If those check out pit the meter in mine and start pulling fuses and go from there.
Old Nov 26, 2013 | 05:53 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: parasitic draw
Anything over .05 amps is considered too much of a draw.
Old Nov 26, 2013 | 06:45 PM
Sojer's Avatar
Re: parasitic draw
Well it can't be a alt because it charges and its new can't be the battery also new. And it only happens when the car sits. I know its no lights or radio ac (all gone but the lights)
Old Nov 26, 2013 | 06:47 PM
TxTtopZ's Avatar
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
Re: parasitic draw
.03mA is considered the standard. There is a formula for checking current draw depending on what size battery is in the car. Only sitting 2 days then dying should be WAY easy to spot by pulling fuses until your amperage stabilizes at an acceptable draw. Are you using an amp clamp or a meter?
Old Nov 26, 2013 | 10:07 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: parasitic draw
Even new alternators can be bad. The alternator itself can be a source of parasitic draw.
Old Nov 26, 2013 | 11:03 PM
Sojer's Avatar
Re: parasitic draw
True I hope not I will look I have a cheap oreillys multi meter so not sure if it can do it but I can get to a better one
Old Nov 27, 2013 | 09:53 AM
TxTtopZ's Avatar
Engine: 5 Liter 305
Axle/Gears: 3.45
Re: parasitic draw
If it has milli-amps it will work. Anything can cause it. Starter, alternator, window motors, circuitry etc. Buy an amp clamp, put it around the negative cable of your battery, shut the doors and take the key out of the ignition, unplug the hood light and wait for it to stabilize. If you have to, shut the door LATCHES and no the doors to keep access into the car and fuses. Start yanking until the amperage goes WAY down 1 by 1
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
deracer
Apr 11, 2016 12:04 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gta892000
Sep 16, 2015 12:37 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
