Ignition lock won't stay in the radio position
Old Nov 23, 2013 | 04:06 AM
daytona2134's Avatar
The car is an 89 camaro rs. when I turn the key backwards into the radio position to turn the radio on it will just pop back into the off position. the radio comes on and will stay on as long as im holding the key back. I don't like leaving the everything powered up when the the car is not running if I want to listen to the radio. The car runs and starts fine and the lock works like it should other than that. I was wondering if anybody knew about something I could to do fix it other than replacing the entire thing? It would be worth it if it weren't for the vats. It kind of feels like that push down key lever thing on the column might have something to do with it because you can see it move a little when turning it but I'm not sure.
Old Nov 24, 2013 | 09:34 AM
Sam L.'s Avatar
Car: 1990 Camaro Iroc-z Z28,1987 Camaro
Engine: 406 Super rammed SBC, LT1 355
Transmission: 4l60E, 700R4
Axle/Gears: disc brake 3.27 9 bolt posi,10 bolt
Re: Ignition lock won't stay in the radio position
mine did this too, i just replaced the whole key cylinder and it works good as new i got it a ricks camaros if you wanna take a look.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
