name this part!
Old Dec 9, 2013 | 05:09 PM
KR81's Avatar
name this part!
Hey guys. Need to know the name of this part and its function. It has 3 wires coming from it. Green. Green/white. Brown. From what I see the solid green runs to inst lps fuse and green white and brown to the dimmer switch. Re placing this part could solve my no gauge lights problem. Thanks.
Attached Thumbnails name this part!-20131210_100846.jpg   name this part!-20131210_100835.jpg
Old Dec 9, 2013 | 05:33 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Re: name this part!
Remote dimmer switch for the instrument lights. Mine went out a while back. You can jump it if you connect the green/white to the green wire IIRC. If the lights work after you jump it, then it is the dimmer.
New Unit
Old Dec 9, 2013 | 05:38 PM
KR81's Avatar
Re: name this part!
Thanks man. I'll give that a go. Since my post here I actually found it by googling the dimmer switch. Since I have seen this mentioned but not named in other threads I hope this will help others. Also the AC Delco pt # is D1509B.
Old Dec 9, 2013 | 05:41 PM
KR81's Avatar
Re: name this part!
Haha just saw your link. Good on ya man.
Success!!!!! Veaceonee, you are a champion. If you're ever in Sydney you got a place to crash and a tour guide lol. Thanks. As soon as I order the part I can see my speedo at night again !
Old Dec 9, 2013 | 09:27 PM
KR81's Avatar
Re: name this part!
Would it be safe to leave these wires bridged? I don't really see the purpose of the dimmer switch anyway...
Old Dec 9, 2013 | 10:55 PM
Veaceonee's Avatar
yes. I ran mine bridged for over a month with no issues. lights are really bright though
Posted from Thirdgen.org App for Android
Old Dec 9, 2013 | 11:47 PM
KR81's Avatar
Re: name this part!
Going to order the part anyway but for now so I have light at night. Thanks again bud.
Old Apr 24, 2014 | 10:17 PM
KR81's Avatar
Re: name this part!
ok so I should've posted this a while ago but I only just got around to ordering the new part.
The day I jumped the wires as described above, when I turned the lights on that night, smoke started to come out from around the headlight/dimmer switch area, then the dash lights went out. No fuses are blown. I just received the new dimmer switch component that is pictured in my first post, hooked it up and still no dash lights.
Any ideas what might've happened when I saw the smoke?
Old Apr 24, 2014 | 10:31 PM
DanzigEx's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: TH700R-4
Re: name this part!
If you still have the old bulbs in your dash lights could of burnt out? Hopefully nothing worse though, here's hoping!
Old Apr 25, 2014 | 02:04 AM
KR81's Avatar
Re: name this part!
Nah they light up if you connect the green/ white wire at the dimmer wheel to a constant power source
Old Apr 25, 2014 | 02:47 AM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Re: name this part!
sounds like the headlight switch burnt to me, if y have another one handy, try plugging it in
Old Apr 25, 2014 | 07:54 AM
KR81's Avatar
Re: name this part!
Thanks but no, I have tried with a brand new headlight switch too.
Old Apr 25, 2014 | 01:18 PM
Barlow8869's Avatar
Re: name this part!
did the new headlight switch come with the dimmer **** too, it may be the manual dimmer if not
Old Apr 25, 2014 | 05:01 PM
KR81's Avatar
Re: name this part!
No it didn't come with dimmer wheel but I opened it and there's nothing inside that looks like it could burn out
Old Apr 26, 2014 | 02:02 AM
KR81's Avatar
Re: name this part!
Bump
Old Apr 26, 2014 | 03:42 AM
Barlow8869's Avatar
Re: name this part!
did you check the power coming from the headlight switch and the manual dimmer to the auto dimmer? if your lights are lighting when you hot wire them, it is not getting power from its power source, i would start from the auto dimmer and see where the last place you have power going in the direction of the auto dimmer is, and that should tell you what you need to replace
Old Apr 26, 2014 | 03:45 AM
KR81's Avatar
Re: name this part!
Yes I came to that conclusion re no power from its source, I'm not sure what u mean by the auto dimmer...
Old Apr 26, 2014 | 08:00 AM
KR81's Avatar
Re: name this part!
Bump again.
Sorry but I really need help with this please, car is going in for registration on Monday and it won't pass if I can't get this fixed!!!!
Old Apr 26, 2014 | 12:52 PM
Barlow8869's Avatar
Re: name this part!
my bad, i meant remote dimmer, sorry about that
Old Apr 28, 2014 | 06:03 PM
KR81's Avatar
Re: name this part!
Going to see an auto electrician, don't know when but I've had enough trying to do it myself. When I get it sorted I will actually post what the issue was so this thread can help others, as it seems like this happens to most late 3rd gen T/A's.
Old May 8, 2014 | 07:04 PM
Jagu07's Avatar
Car: 1992 Camaro RS 25th An.
Transmission: 5 Speed/ Stock
Axle/Gears: Stock
Re: name this part!
look at the schismatics for the instrument light and check all your connections you might have shorted something out not sure what did happen but its really helpful to know where the wires go and you can locate the problem in no time!!!
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
