SES Light Wiring
Old Dec 14, 2013 | 07:04 PM
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
SES Light Wiring
Going with an autometer setup, wondering which wires from the original cluster connectors are for the ses light, I think I probably have some codes, but I'm not sure. In any case it would be good to have. Thanks for reading.
Old Dec 15, 2013 | 03:02 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: SES Light Wiring
If you are asking how to wire in a Ses ? One side of the light bulb goes to switched power usually a pink/blk wire at the ip cluster. The other side of the wire on the bulb goes to pin A5 of your ecm . This wire will be found at the ip it is brn/wht.
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
