yet agian another tail light problem
Old Dec 19, 2013 | 10:33 PM
tetriz25's Avatar
I bought an 89 Camaro 2.8 v6 with a bit of a electrical issue. the tail light blinkers don't work along with the front right light only working when the normal light are on but the left don't work, with the reverse happening when i turn the hazards on. Any troubleshooting advise would be appreciated. Also even on a better note my highbeams don't work...
Old Dec 20, 2013 | 05:29 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: yet agian another tail light problem
If it were mine I would get new bulbs to have ready. Then I would check and clean every ground wire I could find. Ground from battery to the chassis, engine to firewall ground, headlight ground. Then inspect and clean all light sockets and replace bulbs if bad. Then you also have the light switch itself that does wear out over time. Let us know what you find.
Old Dec 29, 2013 | 01:10 PM
tetriz25's Avatar
thank you very the advice, I found out the problem was the lower turn signal light was not connected properly due to bad maintenance once I connected the lower wire I found that my turn signals and main headlights worked. the only thing that doesn't work is the bright headlights...
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
