Did 85 IROC Fog Harnesses Have Relays?
Old Dec 24, 2013 | 09:55 AM
two-if-by-sea's Avatar
Car: 89 RS Vert, 89 Formula, 89 Bird
Engine: L03, TBI 350, none
Transmission: 700R4, 700R4, none
Axle/Gears: 3.42, 3.45, none
I bought this harness, supposedly from an '85 IROC and sold as UNCUT. When it arrived, I was surprised to see that it did not have the relay. The harness looks too simple. I plan on adding this to my '89 RS.
My questions -
1) Does this look like a complete harness from an '85 IROC?
2) Is this thing going to burn up switches, pulling juice straight from the fuse block (I do plan on adding an inline fuse)?
Attached Thumbnails Did 85 IROC Fog Harnesses Have Relays?-100_2936-resize.jpg
Old Dec 24, 2013 | 10:34 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: Did 85 IROC Fog Harnesses Have Relays?
Just looked in my 85 shop manual. There's no relay on the fog lights. It goes directly from the low beam, to the fog light switch then out to the lights. No relay seen on the diagram.
Old Dec 25, 2013 | 08:25 AM
Thanks for looking. Not what I was expecting. As much as I hate to do it, I'll probably end up cutting the harness, where it goes under the dash, to add a relay. May as well do it right the first time.
Old Dec 25, 2013 | 12:38 PM
Jonesyfxr's Avatar
I agree sir. While you're at it, install power window relays too.
Old Dec 25, 2013 | 01:33 PM
Joe Tag's Avatar
The closer to the power source and the load the better. Factory relay mounts on the core support, right about where it looks like your harness is spliced on the hot. Just cut it there, run a fused hot from the battery and tie into the same ground screw for another ground. Hot from the switch is the trigger for relay, new ground is the ground for it.
Old Dec 25, 2013 | 05:49 PM
Jonesyfxr's Avatar
I personally would run a separate ground. I've seen a higher current component burn out a lower of grounded to the same point. I've seen this on supposed factory wiring on the limos I fix.
Just my .02. I even ground fans independent of each other, but that's just me.
Old Dec 25, 2013 | 05:58 PM
Joe Tag's Avatar
" and tie into the same ground screw for another ground"
Did you miss that part or misunderstand it? Two ground wires, one screw.
The relay has very little draw and the second ground is really already overkill.
edit; apparently I misunderstood you, but again the relay has little draw unlike a fan. If a wire burned being mounted in tandem with another, it was probably because it was loose.
Old Dec 25, 2013 | 06:46 PM
Jonesyfxr's Avatar
I think we both misunderstood each other.
All I'm saying is, I've been working on 12 volt wiring for 20 years and have seen a lot of strange things....especially on the limos I fix routinely.
Old Dec 25, 2013 | 07:09 PM
Joe Tag's Avatar
Fair enough, Merry Christmas.
Old Dec 25, 2013 | 07:17 PM
Thank you both. I do appreciate your suggestions.
Caspar
Jun 19, 2016 11:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
mustangman65_79
Aug 12, 2015 06:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
