just wondering...
Old Jan 9, 2014 | 11:51 PM
racerx520's Avatar
just wondering...
i was just wondering how hard it would be to do a a-pillar gauge setup. I was thinking about doing an AFPR and thought it would be nice to have the pressure easily visible, then i got to thinking it would be nice too, to have a transmission temp gauge. but i'm not sure how hard it would be to wire that or how to go about it.
Old Jan 10, 2014 | 07:43 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: just wondering...
I have three gauges on my 83 pillar and I like it very much. Just take your time and follow the instructions an you should be OK.
Old Jan 10, 2014 | 10:32 AM
racerx520's Avatar
i mean more of, how hard and how would you wire up the AFPR to the gauge cluster and also a trans temp gauge
Old Jan 10, 2014 | 10:41 AM
Edwardgp's Avatar
Engine: 454-350
I believe the transmission temperature gauge is a little involved. You will need to drop the transmission pan and drill a hole for the sending unit. It works on the same principle as the cooling system temperature gauge.
Old Jan 10, 2014 | 06:57 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
some put the sender in the line pressure test port.
rockit
Aug 8, 2005 11:21 AM
thirdgen88
Brakes
Jul 20, 2005 04:10 PM
sancho
Jun 30, 2005 12:07 AM
Doward
Jun 3, 2005 12:26 PM
