Replaced my ignition coil
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
The Hypertech one I had failed. Installed a new BWD Select brand remote coil. Car started up on the first turn. And made in the U.S.A.
Car: 1987 Camaro LT
Re: Replaced my ignition coil
Forgot to add that I did install a BWD ignition module as well. I didn't use the supplied grease that you are supposed to used under the module. Instead I read on here to use the high temperature heat compound they sell at Radio Shack. It's a silver compound and the tube is really small. Set me back like $14 bucks or so. Hope it's as good as they say it is.
92camaroJoe
Aug 13, 2015 06:07 AM
