Need help with the dreaded OBD 1.5
Old Mar 6, 2014 | 08:59 AM
CamaroJen's Avatar
Car: 95 Camaro
Engine: 3.4
Transmission: 5 speed
Just rebuilt the 3.4 engine in my '95 Camaro and the service engine light is on. It has OBD I with the OBD II port. Actron has discontinued the 9145 scanner and I really don't want to spend the $350 on Ebay! I found an in interface cable to use with my laptop, and there is a bunch of software out there. Has anyone used any of the diagnostic software that will pull the codes?
Old Mar 6, 2014 | 05:56 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need help with the dreaded OBD 1.5
Can you not pull the codes the reg way by jumpering the terminals in the ALDL connector?
https://www.thirdgen.org/forums/tech...s-dumbies.html
TunerPro
http://www.tunerpro.net/downloadApp.htm
has a file for your car
http://www.tunerpro.net/downloadBinDefs.htm
but you primarily use that sort of software to datalog so you can tune your car
Old Mar 7, 2014 | 10:45 AM
Pocket's Avatar
Car: 91 Trans Am
Jumping pins wont work for 4th gens, tried that with my 95 Formula. Ended up soldering an OBDI ALDL in with the OBDII ALDL so any OBDI scanner could read it
Old Mar 29, 2014 | 07:16 PM
CamaroJen's Avatar
Car: 95 Camaro
Engine: 3.4
Found a scanner that works. Thanks for the advice!
Old Sep 11, 2014 | 06:23 PM
CamaroJen's Avatar
Car: 95 Camaro
Engine: 3.4
G
Last edited by CamaroJen; Sep 11, 2014 at 06:43 PM. Reason: new thread. entered in the wrong spot.
junior419
Apr 7, 2025 11:35 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
92firebirdguy
Sep 10, 2015 10:33 PM
