VATS check
Old Mar 10, 2014 | 01:35 AM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
VATS check
First, hello to everyone and this is my very first post. Major newbee here to a gen3 but not to the chevy camaro. I recently purchased a 91 z28 vert to add to my garage(not a daily driver yep). Ive been slowly fixing all the little things with it. The previous owner gave me one set of keys. Somehow I get the feeling the vats may have been bypassed. Is there a way to test this before I make keys. Can I just put tape over the key resistor and try starting it or is the key picked up by some sensor in the ignition hole. Thanks
Old Mar 10, 2014 | 04:03 AM
((Mike))'s Avatar
Car: 1969 RS Z28 X33 Norwood built
Engine: 383 Stroker
Transmission: T10 4 speed
Re: VATS check
VATS is the reason I wanted an 87. A lot of the VATS cars I looked at had the system either bypassed or there were problems with it. Im glad my car doesn't have it.
Old Mar 10, 2014 | 06:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: VATS check
https://www.thirdgen.org/vats_passkey_system
Bear in mind
there is the VATS "bypass" that uses a resistor to " fool " the VATS into thinking the correct key is being used ; all the VATS functions are still there and operational
and VATS delete in which a device electronically supplies the fuel enable signal to the ECM that usually provided by the VATS module
In the latter case the starter enable relay as to be bypassed to completely remove VATS
Old Mar 10, 2014 | 10:21 AM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
Re: VATS check
This morn I went ahead and put scotch tape over the key resistor and it started up. So I take it that the previous owners bypassed the the VATS then. Now I can just go to Walmart and have a spare set of keys made. I looked under the dash cover to check if a resistor bypass was done and I wouldnt want to try restoring the VATS it looks like a wire mess in there. Thanks for the input.
Old Mar 10, 2014 | 01:57 PM
90_blue_gem's Avatar
Car: 1990 IROC
Re: VATS check
Hey guys, on a similar note, my 1990 IROC won't fire up this morning, ran good last night. In regards to the VATS being a possible culprit, will the CEL flash a code to determine if it is the cause
Old Mar 10, 2014 | 03:31 PM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
Re: VATS check
On the link posted by vettoz, it says code 53. But you can diagnose here https://www.thirdgen.org/vats
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
64goatman
Sep 9, 2015 01:09 PM
383cam
Sep 9, 2015 06:01 AM
tgp1990
Sep 4, 2015 06:24 AM
