More alarm problems...
Old Mar 16, 2014 | 02:21 PM
TheIgnitious's Avatar
Car: 82' Z28 Crossfire
Transmission: Turbo 350
I could've sworn I had this stupid thing wired up right. I am now blowing fuses everytime I hit my power lock switch in the car. Also the keyless locks are not signaling the motors or something, probably something with the wiring. Help please!! I need to attempt to finish this today
http://www.blackwidowsecurity.com/in...%20Install.pdf
How should I hook up these wires especially on lock side. I'm also still confused as to what type of locks I have along with door switch. Sorry to keep editing and adding... But also, what about dome output? I'm normally an expert on this wiring especially since my harness is chopped up from previous owners, but this is kicking my butt!
Old Mar 16, 2014 | 03:02 PM
Re: More alarm problems...
Anyone have any info?? My day is slowly disappearing, please please help if you know anything
Old Mar 16, 2014 | 04:15 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Look at the diagram in the link below.
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
The power lock circuit is in the upper left side.
Note that the existing lock switches just "flip" the 12v feed to the door lock relay which will lock or unlock the door. The way you have your alarm hooked up, it's probably grounding the 12v feed (shorting it to ground) causing the fuse to blow.
I "think" you have a reverse polarity system. Look on Page 13 of your alarm manual for the diagram.
I have never installed an alarm system so you might want to wait for a more informed member to confirm this.
Old Mar 17, 2014 | 06:51 PM
Meant to get back to post yesterday, but I forgot. Yes, it was reverse polarity and works with no problems! Thanks for the help!
1992Z28!
Nov 19, 2015 07:33 AM
Stauf
Aug 24, 2015 08:31 PM
camaro 22
Car Audio
19
Sep 25, 2001 02:53 AM
ADAM NEAL
Car Audio
Sep 19, 2001 11:24 PM
AmorgetRS
Car Audio
Sep 8, 2001 11:12 AM
