Right blinker help
Old Mar 31, 2014 | 04:04 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Right blinker help
Well I had a brake light bulb out so I decided to go ahead and change all the bulbs while doing so.... Well now my right blinker doesn't work correctly. The left side blinks correctly but the right side stays on and does not blink but does light up... It hasn't done this before, I guess I shoulda left it alone lol...
Also before I bought the car, someone has replaced the some of the sockets, they are pretty nasty now and have a lot of yellow goo crap (electrical grease?) down in there. All the bulbs work because I checked them in other sockets on the left side as well. Thoughts?
Old Mar 31, 2014 | 04:40 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Right blinker help
First, get rid of the yellow goo. It is a dielectric grease. I had nothing but problems with the taillights in my 94 GMC truck when I bought it. Found the sockets were full of that crap. Once I cleaned it out, they worked a lot better. Also, make sure you have the right bulb in the blinker. You can swap the left & right ones to test. The blinking is dependent on the bulb providing the proper resistance. If you have a bulb with too low of a resistance, it won't blink.
Old Mar 31, 2014 | 05:13 PM
techno101's Avatar
Car: 1989 Camaro RS
I have the correct bulbs. They are all the same except for the reverse lights. Also when I push the hazard lights on, the light works on the dash and in the rear. One more weird thing. The all the rear lights on the left side are brighter than those on the right side....
Old Mar 31, 2014 | 07:54 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Check the black(ground) wire on that side of the harness. It's probably damaged or cut.
Old Mar 31, 2014 | 09:24 PM
techno101's Avatar
Car: 1989 Camaro RS
Awesome I'll check it tomorrow
Old May 2, 2014 | 09:38 PM
techno101's Avatar
Car: 1989 Camaro RS
Ok fixed it.... The damn bulb was inserted in correctly. I took it out turned it 180* and put it back in. Works fine now ..... Lol. SMH ..
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
bklucas12
Jan 11, 2002 06:44 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
