Will Cruise control still work w/out the VSS functioning?
Car: 91 Camaro RS
Engine: 305 TBI
I am trying to fix my speedo. I did some searching on here for a fix and I just replaced the buffer box under the dash with a used one from ebay with out fixing it. I was under the impression the cruise control wouldn't be working if the problem was the VSS so I thought the buffer box was bad since my cruise still works. Is this true? Could the VSS still be my problem?.
91 RS 305 TBI.
91 RS 305 TBI.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Will Cruise control still work w/out the VSS functioning?
I would say no. It has an input signal from the VSS so it can determine if your speed changes so it can correct it. Here is a link to the diagram for a 92 camaro, should be the same as your 91.
http://www.austinthirdgen.org/mkport...se_control.jpg
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
The sensor on your trans is probably shot. Like a 5 minute fix. Longest part is lifting the car.
Car: 89' Trans Am KARR Rep.
Engine: 305 TBI
Transmission: 700-R4
Axle/Gears: 3.27 Posi Disk
It could also be your VSS Buffer has no power or has gone bad.
Question on the cruise control diagram. I have an 89 TransAm with an 89 Pontiac Firebird Service manual and my cruise control digram don't match the colors on that one for the multifunction lever and cruise control modual for your post. My original harness matches your digram, could Pontiac/Helm have screwed up when writting the manual or does that mean my harness has been swapped out prior to me buying the car?
Joe
Joe
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
" the tbi uses a 2,000 pulse per mile sensor wire to a vehicle speed buffer and from there it sends a 4,000 optical signal
to the speedometer and a 2,000 pulse per mile optical signal to the tbi ecm and cruise control"
So if the CC is working the VSS and buffer ( at least the CC output ) must be working OK
Car: 1992 Camaro RS
Joe
Joe
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cruise Night
Good info from vetteoz and 92RS.
Ill add that the Cruise Control gets its signal from the VSS VIA the buffer.
Due to the fact your CC works, you know the VSS is OK.
You still dont know if the replacement or original buffer is 100% good.
The buffer can be defective in such a manner that is runs the speedo but not the CC or vice versa.
But the above is rare.
You can probe the output of the buffer with an audio amplifier to see if it is putting out the signal for the speedo.
Probe pin B11 gray wire with an audio amp.
If you get that signal to the speedo but the speedo doesnt work, replace the speedo.
Happy Racing !
Even Tho I Might Destroy The Car During The Race, At Least It Looks Gorgeous At The Start
Happy Racing !
Car: 91 Camaro RS
Engine: 305 TBI
Re: Cruise Night
Happy Racing !
Happy Racing !
eightsixseven
Dec 16, 2024 01:50 PM
colton_carlson
Mar 8, 2019 12:21 PM
Street Lethal
Aug 13, 2015 08:28 PM
