Wiper control question
Old Apr 9, 2014 | 07:36 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
well crud. I put on a new steering column yesterday (My wife asked if I could add tilt for her) and the column works fine, but as I was installing it, I noticed that the wiper control only had 4 wires. Mine has 5, but the connectors worked, so I went ahead with the install and I figured I would eventually figure out what the missing wire was. It was part of the wiper control. I have low or high speed for the wipers, and the only way to get them to move is by pushing the spray button, but now they won't park at all. They stay in the same position as whenever I release the spray button. I'm wondering if I need a different switch, or maybe a wiper motor control from a 86 or earlier (the age of the column)
Old Apr 9, 2014 | 08:48 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Wiper control question
I'm not sure, but can you swap them out?
Old Apr 9, 2014 | 08:59 PM
58mark's Avatar
I'm trying to find a picture of a switch from 84 (I think that's the age of the column) that's for a tilt wheel, without cruise, and no wiper delay. that's a hard find.
Not sure what to do at this point, other than put the old column back in
Old Apr 9, 2014 | 09:10 PM
red rock's Avatar
Car: 1987 iroc
Would this be it? http://www.classicindustries.com/198...rts/g4759.html
Old Apr 9, 2014 | 09:12 PM
58mark's Avatar
the lever isn't the problem. It's the switch, which is the wires within the steering column
like this
http://www.ebay.com/itm/230919171824...84.m1423.l2649
Old Apr 10, 2014 | 07:45 AM
red rock's Avatar
Car: 1987 iroc
Yes, i'm sorry, after i posted it i realized what did. Check out Classic industries and see if they have one. http://www.classicindustries.com/camaro/ Then i found this: http://www.rockauto.com/catalog/x,ca...,parttype,4856
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
eddie jr
Aug 25, 2015 06:52 PM
redmaroz
Aug 16, 2015 11:40 PM
slade5612
Aug 11, 2015 07:19 PM
