Battery tie down?
Old Apr 19, 2014 | 01:31 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Battery tie down?
Ive searched this forum to no avail. Any inputs would be appreciated.
I have a 1991 GTA with the 5.7. My battery is located on the driver's side, behind the headlight.
I'm missing the battery tie down. It looks like my car is supposed to have two vertical posts/pegs on the battery tray (located to the rear of the battery, the stick up about a half an inch or so). One of these posts is also missing.
The local parts stores have a bunch of universal tie downs, but I'm missing the original, so I'm not sure which I need.
I'd rather go with OEM, but in the end, I'd like the option that does the best job.
I found this option from rockauto:
http://www.rockauto.com/catalog/more...369&cc=1251773
But, it looks like its missing the long steel hooks.
Any ideas where I can get the tie down and the missing post/peg?
Thanks!
Bill
Old Apr 19, 2014 | 02:38 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Battery tie down?
the one from your link is what the factory used. it's held on with about a 2" long, metric bolt.
Old Apr 19, 2014 | 03:25 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
As stated, the tray should be threaded for the bolt, but sometimes the bolt is broken off inside of the threaded portion. The bolt has an odd pitch and is typically pointed at the end (probably to help line it up).
If you happen by a junk yard you could probably get the pair (block & bolt) for free or a nominal cost. Very common out there.
Old Apr 19, 2014 | 06:25 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
Had the same issue a few weeks ago. Lots of GM cars use the same hold down. The bolt is about 2" long as stated above. On my 89 Formula, the hold down goes on the side closest to the firewall. The hole in the tray is threaded. I had to use some PB Blaster on the hole and work the bolt in and out several times to get it work.
Old Apr 19, 2014 | 06:44 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
found one and the bolt under my workbench. if you need it, let me know.
Old Apr 19, 2014 | 08:04 PM
wgripp's Avatar
Thanks for all of the help, guys! Does anyone have a part number for that bolt?
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
drumstixer
Sep 29, 2015 03:02 PM
