Alternator Sine Waves
Old Apr 23, 2014 | 04:01 PM
roysatikas's Avatar
Car: 91 RS
Engine: 4 bolt 350, .060 over
Transmission: 700R-4
Anybody have an idea, process or technique for measuring sine waves? I have an old (10+ years) alt putting out good voltage. Problem: + - 3 degrees of timming variance at higher rpms 3 to 6 k. I read recently that this may be my problem. (every other possible avenue for this issue has been addressed)Has anyone experienced this?
Thanks in advance.
Roy
Old Apr 23, 2014 | 06:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Alternator Sine Waves
Try shimming your distributor.
Old Apr 24, 2014 | 06:01 AM
roysatikas's Avatar
Car: 91 RS
Thanks Apeiron, I verified oil pump driveshaft length clearance of .010 to .040 during initial assembly but I will check it again. Thanks for the idea as I have not rechecked that since pre assembly fitting.
Roy
Old Apr 28, 2014 | 05:36 PM
roysatikas's Avatar
Car: 91 RS
Cheched up and down movement of the main shaft as D.U.I. Distributors instructs. Yes I have movement so the distributor is not bottomed out.
Old Apr 28, 2014 | 10:09 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Can't you just measure AC voltage? IIRC, you should never see more than 3VAC or you need a new alternator (Or to replace your regulator in the alternator)
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
