Hatch pull down nightmare.
Old May 2, 2014 | 02:02 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
So, the PO really screwed up the hatch wiring. And I am confused beyond reason. I have an '89 Camaro, and these wires don't make sense. And the wiring diagrams are doing no help for me at this point. Would someone please make a picture walk through of going through each wire and where it goes and what it connects too? It would be greatly appreciated.
Old May 2, 2014 | 02:47 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Hatch pull down nightmare.
I don't know how to make/upload a diagram but I drew one when I was figuring out how it worked. Mine is '91 so not sure if yours is the same or the earlier one. If no-one can post a diagram and easy explanation I could scan my diagram and send it to you if you want.
Old May 2, 2014 | 04:08 PM
Annihilate's Avatar
Engine: 5.0
That would be nice. I think the harness I pulled from the junkyard is from a 91 or 92.
Old May 13, 2014 | 12:12 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
There were two styles of hatch pull-down unit for 1991. The early version has a metal frame (where it attaches to the car body) and weighs abiout 7 lbs. The late 91-92 version has a tan colored molded plastic frame (where it attaches to the car body).
For the early 86-91 style, the entire wiring is part of what is called the striker-sensing switch.
It is pretty simple to hook up the wiring. The blue wire with either a small black connector on the end (88-91) or with a larger white connector (86-87) connects to a red/white stripe wire which is a constant 12v. The black wire with a small ring terminal connects to the body ground location just below the pull-down unit. There is a white wire with small black connector that was used only for 89-early 91 models. For those years only it connects to a black with orange stripe wire to provide a switched ground to turn on and off the rear compartment hatch light. The 86-88 models used a manual switch to turn on and off the hatch light. There is a relay that plugs into the relay socket. If you are concerned if the relay is working properly just unplug it and see if the pull-down unit works properly. It whould function without the relay being plugged in.
In a nutshell, that is it as far as wiring the hatch pull-down unit. There is an optional hatch release solenoid. If need help with that let me know.
Here is a link to what the striker-sensing switch and the wiring looks like.
http://www.top-downsolutions.com/hat...h-pull-down-un
Lon Salgren
Old May 13, 2014 | 06:23 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
If you have access to a welder, just spot weld the two parts together. It will revert it back to the earlier style that GM used before they lost their minds and made it overly complicated. It's easy to adjust it out the right height so the hatch closes completely and securely
One of GM's dumbest designs ever
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 11, 2015 11:36 AM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
90formulaVortec
Sep 7, 2015 06:54 PM
