4 fusible links near battery. Stamped numbers?
Old May 3, 2014 | 09:13 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I got an 86 IROC. Im about to begin rewiring the mess that is near the battery. My question is about the fusible links. There are 3. One has a 20 stamped on it and the other 2 have the numbers 16. Are these the amp ratings? Also the big barrel looking link with 4 wires coming out of it has the number 20 on it. Any advice would be great. Thanks.
Attached Thumbnails 4 fusible links near battery. Stamped numbers?-484203_352343511538956_812418702_n.jpg   4 fusible links near battery. Stamped numbers?-phpcmvvdhpm.jpg   4 fusible links near battery. Stamped numbers?-phpxcjqympm.jpg
Old May 3, 2014 | 11:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 4 fusible links near battery. Stamped numbers?
Are these the amp ratings? .
Yes
Old May 4, 2014 | 12:27 AM
Originally Posted by vetteoz
Yes
Roger that vetteoz. Thanks.
Old May 5, 2014 | 04:48 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Ampacity Veracity
Links usually are identified by indicating their internal gage, not by amps.
One usually selects a Link two commonly available sizes physically smaller.
For example, if you want to protect a 12 gage circuit, you usually insert a 16 gage Link.
If you wanted to convert to fuses, (not recommended) they would take up a lot more room, and not be as safe because you will have to run unprotected wires to the new, large, fuse blocks, due to the fact you would be using fuses of 50 amps and up.
A Link protects a circuit downstream which branches out to many fused circuits.
Happy Racing !
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
Old May 6, 2014 | 06:02 AM
They are the wire sizes, in mm.
2.0mm & 1.6mm.
They will actually melt at around 80A for the larger and 50A for the smaller, depending on how long the overload lasts.
Even worse about fuses is, there's a contact point (2 individual pieces of metal that merely "touch") at each end of them; virtually 100% positively guaranteed to result in intermittent connections at a CRITICAL place, more likely sooner than later, on account of the high power flow at that point. If that's what you want to install into your car (intermittents... works sometimes, fails randomly), then fuses are just the way to do it.
Old May 22, 2026 | 04:42 PM
Bruceak04's Avatar
Car: 89 and 91 Camaro Convertibles
Engine: 305 and 350
Yes
those are the wire gauge sizes for the fusible link wire only. not amps or the the standard wired side wire. The black tube is a insulated butt connector only.
Ct1987
Jul 12, 2020 07:25 PM
rjpunke
Aug 15, 2016 04:32 PM
cjsweeney
May 14, 2012 12:23 PM
joecool1979
Oct 14, 2011 08:54 AM
19transamtpi86
Apr 12, 2010 08:29 AM
