battery not charging
Old May 4, 2012 | 10:17 AM
cjsweeney's Avatar
My car is running at about 11.8 volts when no lights or radio on or anything. I put a new alternator in and new battery, all the connections are solid. The alternator is putting out 14-16 volts but there not getting to the battery. The power return cable also seems to be fine, i replaced the terminals on both ends. Any help would be greatly appreciated, thank you.
Old May 14, 2012 | 09:32 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The Missing Link
There can be only one reason for that, and it’s an open circuit.
Check the fusible link located at the junction block near the battery.
Fusible Links usually look like a one inch plastic rod in line with the wire.
Happy Racing!
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
Old May 14, 2012 | 09:56 AM
cjsweeney's Avatar
Re: The Missing Link
I plan on replacing the fusible link along with the whole wire because when i took a look at it, along the whole wire the copper strands were charred probably causing resistance. What size inline fuse should i put into the wire though?
Old May 14, 2012 | 12:23 PM
NINÅ's Avatar
Transmission: 765R4
Use a 12 AWG fusible link.
Happy Racing!
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
drumstixer
Sep 29, 2015 03:02 PM
RS Reaper
Sep 27, 2015 07:04 PM
