Replacement for the factory FIAMM horns?
Old May 15, 2014 | 11:38 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
I want to replace the horns in my 1986 Z28 but I really want to avoid using the universal junk that most of the auto parts stores carry. When the horns went bad in my gf's Buick Rendezous, I fiddled with a universal horn bracket and then I ended up buying replacement AC Delcos on Amazon that were direct fit and had all the adapters needed for about the same price as the universal units.
I haven't had much luck finding affordable factory replacements for the FIAMM horns. Oreilly wants (Delco) $51.99 for the low and $77.99 for the high note. What have you all used as replacements?
I see the Borg Warner universal horns and the FIAMM universal 315-2T and the 310-2T horns but nothing direct fit.
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Dec 31, 2015 04:40 PM
eddie jr
Aug 25, 2015 06:52 PM
fonzie85
Aug 13, 2015 11:50 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
