Steering Wheel - How does this come off?
Old May 25, 2014 | 02:45 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Hello,
My turn left turn signal doesn't cancel, so I bought a new cancel cam and am hoping to install it today.
When I bought the car, it had an aftermarket Grant wheel on it, which I replaced. I just took the wheel back off, but I'm not sure how to continue - see attached pick.
Does this piece come off with a steering wheel puller? I think once I get that off, I have to depress the lock plate to the cancel cam. I have the lock plate tool and I have access to a steering wheel puller, I just want to make sure I do this correctly. Thanks.
Old May 25, 2014 | 02:47 PM
Blue1990camaro's Avatar
Re: Steering Wheel - How does this come off?
yea mine had a grant one with the same piece your refering to, i had to gently tug on it with a puller to get it off, it just slides onto the splines on the steering shaft
Old May 25, 2014 | 02:52 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Okay, thanks for the quick reply. I'm off to borrow the steering wheel puller so I can this.
I just realized that my horn has never worked, either - might be a good time to look into that as well although I don't know if I still have the stuff that came with my Grant wheel.
Old May 25, 2014 | 06:23 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Just as a side note, I doubt it is your cancel cam. That's just a piece of plastic. Unless it's busted when you get in there, I'd look for a spring to be missing off of your turn signal switch.
Old May 28, 2014 | 04:00 PM
anytime, and u can order all the stuff u need directly from grant if your missing anything, all i needed was the adapter kit and it all went right together, which wheel do u have?
and yes i agree for a missing spring also.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
