Speedometer Messed Up
Old May 27, 2014 | 09:47 AM
Camaroz28iroc-z's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: LB9
So the other day I figured out that my speedometer is screwed up. In order to go 30mph I have to have the speedometer roughly around 37mph, in order to go 45mph I have to have the speedometer at 55mph, and in order to go 55mph I have to have the speedometer around 68mph. I haven't really looked into it much but I was wondering what you guys thought could be the problem. Any help would be appreciated.
Old May 27, 2014 | 09:52 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: Speedometer Messed Up
Perhaps your vehicle speed sensor (vss) needs to be replaced.
It may be delivering a false input signal to your speedo.
Old May 27, 2014 | 10:44 AM
Joe Tag's Avatar
Your speedo should be cable driven. VSS is not the issue here, but wrong speedo gears in tailshaft for your tires/rear gear ratio combo. Mine is the polar opposite of your problem. Speedo says 30 MPH and actual is 37. I just use my Garmin for the speed, also tells you the limit for the road you are on. There is a sticky for figuring out which drive and driven gears you need for X tire size and X gear ratio.
$750 L98
Feb 1, 2025 02:25 PM
F-body-fan
Jan 12, 2023 01:49 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
